Re: IH 684 Fuel Filter Housing - NEED HELP
Posted by Jimb2 on August 06, 2011 at 17:21:20 from (142.163.230.78):
In Reply to: Re: IH 684 Fuel Filter Housing - NEED HELP posted by RTR on August 06, 2011 at 15:44:01:
Hi RTR, you will have to bleed the brakes. The
brakes are supplied by hydraulic fluid returned
from the hydraulic oil cooler in the front of the
rad.
Procedure to bleed brakes:
To bleed the brakes there is a bleeder screw on
top of each rear axle, looks like a grease zerk.
Require clean bucket and 1/4 or 5/16 inch clear
tubing that will fit over bleed screw nipple.
To bleed the brakes run the tractor until the
Hytran hydraulic fluid reaches operating
temperature.
Run engine at fast idle 1400-1600 RPM, block rear
wheels.
1)With tubing connected to nipple on bleed screw
and other end in clean bucket, loosen bleed screw
and let hydraulic fluid drain until air bubble
free, then close bleed screw. Repeat on other
brake. Do not pump brakes while bleeding.
Top up hydraulic fluid with fluid caught in
bucket, make sure transmission fluid level is full
or over full. Also check for leaks by bottom of
dash and along top of transmission cover. Brake
lines run from under battery box along top of
transmission to rear axles.
May have to repeat bleeding and if bleeding only
lasts a few days then repost and I will give a
procedure to diagnose if it is leaking seals in
brake piston.
JimB
