Re: H engine rebuild
Posted by CNKS on August 06, 2011 at 18:10:47 from (216.144.104.128):
In Reply to: Re: H engine rebuild posted by PaulGinMN on August 06, 2011 at 18:06:32:
Pulling the crank is simple, if you can measure accurately (I can't), then you should measure the mains. It is likely that they too are ok. It is a lot easier to do with the engine out. If you are doing it in frame, I see your point.
