Re: H engine rebuild
Posted by El Toro on August 06, 2011 at 18:39:53 from (108.15.86.54):
In Reply to: Re: H engine rebuild posted by PaulGinMN on August 06, 2011 at 18:01:02:
I would have that crankshaft measured for wear at your local auto machine shop. They can determine if the crank needs to be ground undersize. They won't grind it unless it needs it. It may just need to be polished. Buy your bearings from them as they will furnish the correct bearings. I would have new cam bearings installed too. Hal
