Re: 1206 shifter adjustment
Posted by The tractor vet on August 06, 2011 at 18:44:14 from (75.19.127.83):
In Reply to: 1206 shifter adjustment posted by LarryT on August 06, 2011 at 17:38:57:
Usually , and i said usually this problem all starts off from the clutch trans brake and dump valve adjustment getting out of wack , then the tugging and jerking on the shifter and this starts everything snowballing. and the next thing ya know YA Can't get it into reverse . To fix it will depend on just what is wore out and loose . Being that she has a cab on it it is going to be a good bit of work . First lets start off by getting the clutch adjustment set then ya move on to the trans brake then the dump valve and you can find my way of adjusting them in the archives here .Next pull the dash cowl off and see what all is loose and sloppy and get that fixed then move on down to the linkage under the platform and replace the two headed pins and see if this has helped . as to how much you have gained you may not have to go any feather . BUT if the top of the range transmission cover has ware and the cam that is under that cover is wore and if the reverse shifter rod that goes down to the shifting fork has the little keyway wore out then your going to have to tip the cab or pull the cab and deck plate to remove the range trans cover . and also the side cover on the left side of the rear end housing. There is no real adjustment to make up for ware . She will need to be fixed and since i can not see for myself how much fixen , that you will have to figure out . To have them shift wright ya can not have tomuch slop . I have repaired a bunch over the years , some were easy fixes and others took lots of work and parts. If ya were close to me it would not take long to figure out what was needed and not to long to fix.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
