UPDATE on my Cub tranny
Posted by Scott Hansen on August 14, 2000 at 09:16:16 from (130.187.27.94):
Well, finally my Cubb tranny noise got the better of me, so I took her apart again. This time, I completely emptied the case of gears. I took out the reverse idler and both shafts so I could get a good look at what was happening. I took all of the output shaft gears out and put them in order on the makeshift workbench I had (you KNOW what's coming here...) then I dropped them. So I had to call my son at my place, have him get out the parts book and explain how they all go back together. Last time I deduced, with Big Don's help, that the reverse idler and the reverse gear were making most of the noise. I found out that there are two identical gears in there, and that I could swith the reverse gear with the better one. I did, and it seemed to quiet it down quite a bit. Not as much as I wanted, but there had been water in there, and some gears were pitted rather badly, so there was bound to be some noise. The one I switched out meshes well, so I was pretty proud of myself. You can also turn gears around so that rounded teeth face the other way. Kind of gives them a new start....kind of. I will be posting pics of the Cub when I get them back. Thanks for all of the help. I learned quite a bit about the drive train.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
