Re: IH 130 transmission oil
Posted by gene bender on August 07, 2011 at 12:59:11 from (207.177.56.122):
In Reply to: IH 130 transmission oil posted by Chris in WNC on August 07, 2011 at 12:46:44:
The lube for the final drives is in the pan at the bottom. That lube also gets to the top for the pinion gear and bearing .You need to drop the pan to change the lube. Your tranny and pto can be drained by removing the drain plugs. You can fill with 90wt or even heavier. I use the 150wt.
