Re: 666 hydraulic fluid
Posted by pete 23 on August 07, 2011 at 14:17:39 from (74.32.234.149):
In Reply to: 666 hydraulic fluid posted by Butch Ia on August 07, 2011 at 13:04:01:
Check each individual drain plug area and you may be able to get an idea. Probably too late now, but I like to drain each plug into a clean white pail to pick up on which area if any has a problem. I don't know of any particular suspect bearing in that model. You can jack up each axle and check, watch as you lift to see if axle shifts, you more than likely won't be able to detect any looseness unless you put a finger or indicator on it. Then you start pulling plates and covers etc and start looking. Could be one of many bearings.
