Re: pilot operated check valve
Posted by pete 23 on August 07, 2011 at 14:23:16 from (74.32.234.149):
In Reply to: pilot operated check valve posted by karl f on August 07, 2011 at 10:24:27:
The check valves require hyd pressure to allow them to release so on a single action cyl you need to hold the hyd lever while lowering. If you have them hooked correctly you cannot lower an implement unless tractor is running.
