I don't remember your question at that time, but if you had pump off, with window on side of pump off, turn engine to 3 degrees before top dead center and the lines on pump should line up for static timing. This is with cyl one on compression stroke. Pull a glow plug out of number one if you are not sure it is on number one and feel for compression as you turn engine. I have a crank but using starter to get close and then using fan works. If that is ok, make sure all glow plugs are working, return line is not restricted and intake or exhaust are not restricted. There is automatic advance timing also but you have to have it running and a window or timing light to check and adjust that.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
