Posted by farmall706 on August 07, 2011 at 15:55:33 from (50.103.5.206):
I had posted on my issues of having no pressure in the lube circuit or sensor port. I have 200 PSI in the bottom port. The PSI did not change when I shift the T/A. Today I plugged the line just before the brake valve and tested my pressures again. I have 200 PSI in the bottom, and 20 in the lube circuit. The PSI drops just a little for a second now when I shift the T/A but returns to 200 PSI. I believe this is indicating I am loosing to much oil thru the brake circuit? Some have talked about a orfice in the line. When i removed the line from the brake valve I see nothing but the fitting? Is this orfice built into the fitting or is it a seperate piece. I had stated that I replaced the brake valve with what the salvage yard told me was from a 766.
I hear no more noises coming from the MCV when tractor is running with the brake line plugged?
I think I have found the problem, I did not drive it because of not having the brakes. Do I just ask the parts counter guys for a brake orfice?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
