Re: IH 684 Fuel Filter Housing - NEED HELP
Posted by Jimb2 on August 07, 2011 at 17:02:10 from (142.163.224.142):
In Reply to: Re: IH 684 Fuel Filter Housing - NEED HELP posted by RTR on August 07, 2011 at 11:14:46:
Hi RTR, I guess you figured out to block the
wheels so the 684 does not run over you. Check for
oil leaks from under the dash and from under the
cover on the top of the transmission. This is
where the brake lines run. The other possibility
is the brake wheel cylinders are leaking.
Hopefully the parking brake still works. Be very
careful always to disengage the parking brake
before moving the tractor.
Nice looking tractor and loader. Did it have a T/A
and someone removed it or the plug for the hole to
the left of steering column was just lost?
My brother has 454,495,684 and 3230 with 2350
loader.
JimB
