Re: Re: Re: Re: Re: TWO PROBLEMS, HELP
Posted by The Red on August 14, 2000 at 09:56:08 from (206.246.187.2):
In Reply to: Re: Re: Re: Re: TWO PROBLEMS, HELP posted by VINCE on August 14, 2000 at 09:04:25:
You can pull the hub assembly off without removing the entire water pump. There is a grease seal in each end and yes you can order just them. Sounds like you will need more packing material. I always buy at least 2 packs of the material at a time. One is usually inadequate.
Post A Followup
: Re: Re: Re: Re: Re: Re: TWO PROBLEMS, HELP
