Re: 1952 farmall super w6 power steering
Posted by Bob M on August 07, 2011 at 20:24:23 from (69.207.87.100):
In Reply to: Re: 1952 farmall super w6 power steering posted by matt beckner on August 07, 2011 at 19:49:00:
Another possible alternative is stick a Charlynn PS kit in the steering shaft ahead of the gear box. A friend did this to his MM G and a Case 900 - they both now steer nice and easy. No reason it can't also work on an SW6.
Downside will be cost. You need the torque generator itself, a hydraulic manifold block, shaft U-joint, flow divider (priority valve) and several interconnecting hoses. Figure on $800 - $1,000 unless you can score these parts at a boneyard.
