Re: Sawtooth throttle
Posted by pete 23 on August 08, 2011 at 09:15:58 from (74.32.234.149):
In Reply to: Sawtooth throttle posted by IAtractorKid on August 08, 2011 at 05:39:36:
The handle has to have a little play to twist enough to hold but can't be sloppy loose. I cut the bushing out of the handle, actually, I think I press them or drive them out and install a new bushing made from steel pipe bushing stock and then size it to get just the right amount of twist. Have done it to all three of my H and M's. Also, the spring has to be good, rusty ones lose their tension. Or, am I reading this wrong and you bought the whole assembly with lever, spring and quadrant.
