Looks to me like the ball shank is peined over with a large drop hammer from the forge room at IH. Probably done while hot. It is recessed so it will be hard to grind out the deformed metal. But I am guessing that the original ball with shank has already been removed and replaced with a bolt.
Parts book lists the ball with shank as one item and the wishbone with ball as another item. I am thinking that one or the other is available as new aftermarket. See if Mike at Steel Wheel Ranch can get those parts. In any event, he will tell you the best way to repair your problem. Might be able to source either part from IH.
Never replaced the bushing but it seems like one would jack up tractor to relieve the weight on pivot. Then you would drive out the bushing and pin. There should be a cross bolt to retain the pin.
Don't know how a service rep or farmer could install just the ball unless the replacement ball stud has threads and a nut.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
