If it was converted to negative ground when it was converted to 12 volts it should still be neg grounded unless you or someone changed it. The wire from your ignition switch should go to the + terminal on your coil. If your tractor is sitting out in the rain you probably will have water inside the distributor & cap. It will also get in the plug boots. Any of these can cause a no fire to your plugs. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
