Re: Mccormick Deering W 4
Posted by Zachary Hoyt on August 08, 2011 at 15:36:49 from (184.10.234.29):
In Reply to: Mccormick Deering W 4 posted by rlfervan on August 08, 2011 at 15:32:40:
That hole is probably for the starting tank with which the tractor would have come from the factory, if the hole is back near the gas tank end of the hood. I have had wartime Hs with metal knobs, so I assume the same is true for the W4.
Zach
