Re: Farmall M water gauge disaster
Posted by Tom Fleming on August 08, 2011 at 18:15:08 from (67.20.249.95):
ok, I am going to ask a fairly dumb question. Why not just drill it out and retap it? Find the correct drill size for a 1/2" NPT tap, and drill it out. Then invest in the 1/2" NPT tap, they are NOT that expensive.
I only go so far, then I drill and retap. Only drawback there is that you need to be sure to be centered.
ps. teflon tape or pipe dope will work well if you damage one side of the hole. Locktight also makes a thread sealer that will correct damaged threads if the damage is not too drastic.
