Re: Farmall H transmission problem
Posted by Armand Tatro on August 08, 2011 at 19:17:57 from (98.227.26.140):
In Reply to: Farmall H transmission problem posted by Zachary Hoyt on August 08, 2011 at 12:22:19:
Why is the Super H a parts tractor and how good is the motor in the H. Seems to me it would be best to put H engine in Super H tractor especially if you have a stage 2 Super H with live hyd. You would have a much better tractor and maby an easier transplant. Something to consider. Armand
