Re: Farmall A Casting codes
Posted by gene bender on August 09, 2011 at 05:16:54 from (207.177.56.122):
In Reply to: Farmall A Casting codes posted by Keith 44 2N on August 08, 2011 at 09:52:11:
The code should be behind the steering shaft as thats where mine is almost all engines thats where it will be. Looking at the block lower right side just above the pan towards the front.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
