Posted by Tom Fleming on August 09, 2011 at 07:48:50 from (67.20.249.95):
to be honest, 9 times out of 10, I get partway through the drilling and the broken off piece comes loose. Also, it is helpful to start with a drill bit that is 2-3 sizes smaller than the final size for tapping. Work your way up. Patience here is critical, but I have always gotten good results with this method.
I just got done rebuilding the carb for my regular. The idle speed screw broke off flush. It was steel, and the carb is brass. Nightmare thoughts. However, I started with a small drill bit and worked my way up, slowly and patiently. Ended up having to drill to the final size for the tap. Had to buy an uncommon tap size 12-28. All turned out well, and the new screw goes in like a champ.
Bottom line, take your time, drill it out, and retap if necessary. Worst case, you can JB weld a new bushing in there if necessary, or have one brased in if a total melt down occurs with your efforts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
