Re: Gas Tank Sealers
Posted by sflem849 on August 09, 2011 at 11:40:49 from (69.197.84.39):
In Reply to: Gas Tank Sealers posted by Super-H-Mike on August 08, 2011 at 13:18:43:
Most shops would do either. Just be sure you are clear with them when you take the tank in. If you were using the tractor for farming everyday you could probably not coat it. But most of us only have 1/4-1/2 tank of fuel and that leaves a lot of potential for rust. If I went to the work of getting one boiled out or I cleaned it myself I would probably go whole hog and coat it as well.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
