Re: super m carb
Posted by rustyfarmall on August 09, 2011 at 11:50:10 from (216.248.71.224):
In Reply to: super m carb posted by charlie reed on August 08, 2011 at 18:00:11:
It is strictly a coincidence. Check for proper fuel flow to the carburetor, make sure you don't have any vacuum leaks such as at the carb to manifold gasket, or manifold to engine gaskets. Vacuum leaks often times will not show up until after the engine has been running for awhile.
Might also too little valve clearance, which also does not show up until the engine is warmed up.
Might also be an ignition coil getting ready to go south on you.
