Power assist steering problem
Posted by teachingscience on August 09, 2011 at 13:00:48 from (209.33.94.227):
I"m working on a 504 with factory power assist
steering. It has a unit below the steering wheel
for hydraulic assist that turns the shaft going to
the steering gear. My problem is that the diverter
valve that draws fluid before going to the aux
outlet doesn"t apply any pressure the the
steering. I"ve adjusted the screw all the way in
and out with not change in pressure. Is it
repairable or is there a common problem that
happens with those valves?
Thanks all and God Bless
