Re: M Hyd Pressure #
Posted by D Slater on August 09, 2011 at 18:18:54 from (184.15.12.187):
In Reply to: Re: M Hyd Pressure # posted by Wayta on August 09, 2011 at 17:34:53:
Depends on the use. 900 is better than most M belley pumps put out and would probably work for most old IH implements. If running add on power steering and other hydraulics from the same pump it may not be good enough. Most don't notice 900 PSI as being a problem until the power steering starts getting weak.
