Probably not much difference in total effect, but the larger tires will croud the furrow. In either case the plow is OK for the tractor. With it in the ground, all colters should cut 14" wide strips. Adjust the furrow wheel to make this happen. Depth should be equal on all bottoms, and the colters cutting to the left of the frog some but not more than 5/8" Check the landslides to be sure they are not woen such that the plow pulls crooked. (tapering to the rear of each is not desirable). I would use the smaller tires, as plowing is not done with wet ground. The traction will be fine. Used or new windshield wasser fluid, or Rimguard (beet juice) will not rot the rims, and is a good ides. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
