Re: 450D Power Steering Again
Posted by pete 23 on August 09, 2011 at 19:11:37 from (74.32.234.149):
In Reply to: 450D Power Steering Again posted by labman98 on August 09, 2011 at 18:44:13:
Are you positioning it at an angle. The diesels tilt the behlen unit off toward the right side and brace goes down to one manifold bolt. Gas engines they stand it straight in line over valve cover. And, no, all tractors don't come with the flow divider valve and do require a whole different regulator valve assembly and first hydraulic valve if you want to go that way. Can put on a seperate pump instead if you want to go that way. Hard to find a good used regulator valve assembly with the flow divider you need. Most are worn out. Might get lucky.
