We bought a new SM in '54 & pulled a 3x14" # 16 plow behind it until the mid '60s. Weight required will depend on soil type,& plowing depth. WE ran 2 sets of weights on the landside wheel + a dual with cast iron wheel, 6-8 weights on the furrow wheel & fluid in both rear tires. Always plowed 9-10" deep in 2nd gear & once in awhile had to drop to 1st. Our soils are Sable & Ipava loams, both heavy,black soils that tend to be poorly drained. Rear tires were the qvivalent of todays 13.6 x38s
If tire diameter is greater with the 15.5s over the 14.9s I think the 15.5s would hurt your tractor's performance. You'd definetely have to drop a gear. A good friend of mine tells the story of having a SMTA with 13x38 tires & when plowing along with his dad on an M he would outrun his dad. He had 14.9s pput on his SMTA & said his dad would outrun him with the M because he had to drop a gear so traded th 14.9s for a set of 13.6s.
I wouldn't worry too uch about the 15.5s causing problems because of width. I have plowed several thopusand acres with tractors with either 15.5s or 18.4 ties pulling 14" plows & never had a bit problem.
AS far as setting the plow, do pretty much as would said on the coulters, make sure landslides, shins, & shares are good. plow is level side to side & front to back when plowing and drafts in a straight line. We always set our hitch / furrow wheel so that the front bottom cut 2" more than the moleboard width of cut - 16" in your case. That way you didn't have to run the rear tire aginst the furrow sidewall to get a full width of cut. But at the same time don't drive too far to the right & get an undercut with the front bottom. When done the field should look like it was plowed by one big plow. NO ridges or valleys where the front bottom throws against the last bottom of the previous pass.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
