Once you get the plow set up correctly, and lube all the grease fitting liberally, go a round or two with it set shallow, and run as fast as you can (fourth gear compared to third) to get the bottoms shined up, stop often & clean the dirt from the shares with a stiff putty knife, once dirt does not stick to the shares you have it shined up & ready to do some good work, it will then pull much easier.
I beleive you will do just fine with a single wheel weight on each side & use the tires you have now, the trick is to get the plow set up for the conditions. My experience has been most plow days are set way in advance with little consideration for soil conditions. This is common and you just have to learn to do the best you can with what you have to work with.
ps. Sorry Joe, looks like we posted our replies at exactly the same time, great minds think alike.
This post was edited by rhtx55 at 19:46:02 08/09/11 2 times.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition.
... [Read Article]
Latest Ad:
[More Ads]
