Re: 706 trans gear replace
Posted by DeltaRed on August 09, 2011 at 21:15:53 from (174.16.71.96):
In Reply to: 706 trans gear replace posted by dogone on August 09, 2011 at 17:55:35:
#0 hrs is about right,provided it has no cab.But,you dont have to remove the axles,lift cover,etc.Split it at the flywheel houseing and the rearend,hang the transmission on a stand and go to work.while you are in there,replace the TA,and clutch.As I recall,IH flat rate says 20 hrs for a TA job(cabless tractor),wich is esentially what you are doing(laborwise anyway).
