Re: Help me with plowing advise with my Super M and #16 ...
Posted by DeltaRed on August 09, 2011 at 21:37:29 from (174.16.71.96):
In Reply to: Help me with plowing advise with my Super M and #16 plow!!! posted by Mike1972chev on August 09, 2011 at 17:38:59:
Save your money,use the tires you have-unless you just gotta have new tires.Like theOther guys have said,put 2-3 wts on the land wheel,0-1 wt on the furrow wheel.You gotta have some slippage(10% is idael).The plow is a good match.Now get after it and plow!Have fun!(Yes,I have plowed 100s/1000s acres with a SM,706,1256,etc.kinda know what I'm talkin about!)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
