Re: Removing chloride from tires
Posted by mkirsch on August 10, 2011 at 04:58:27 from (67.253.161.186):
In Reply to: Removing chloride from tires posted by John Lundberg on August 09, 2011 at 17:23:25:
If all you want to do is pump the fluid out of two tires, get the cheapest pump you can get, even one of those cheap drill pumps from Harbor Freight.
The "right" pump is going to be way more money than you want to spend.
Get the adapter from Tractor Supply.
Most of the fluid will come out via gravity with the valve stem at the bottom. You can get about 90% out if you let the weight of the tractor flatten the tire.
Suck the rest out with the drill pump. You'll never get it all. The only way to do that is replace the tube.
