Re: Removing chloride from tires
Posted by glennster on August 10, 2011 at 05:47:44 from (76.222.56.245):
In Reply to: Removing chloride from tires posted by John Lundberg on August 09, 2011 at 17:23:25:
john, if you want an inexpensive route instead of a pump, pick up the fill adapter kit from napa, a 1/2 or 3/4 inch pipe tee, schrader valve and a hose sillcock. put the sill cock on one side of the tee, the schrader valve in the center part of the tee, and connect the last outlet to a section of garden hose going to the fill valve. park the tractor with the valve stem on the bottom, attach the fill valve set up, shoot some air in the schrader valve and open the sillcock. air pressure in the tire will then force the chloride out. you can attach a garden hose to the sillcock and pump the water into a tank or old roundup drums. when the fluid stops coming out, just close the sillcock and add more air. its cheap and quick.
