Re: m valve interchange
Posted by rustyfarmall on August 10, 2011 at 06:49:34 from (216.248.71.224):
In Reply to: m valve interchange posted by lee oh on August 10, 2011 at 05:31:33:
If the 450 is a distillate tractor then yes, the valves would be the same, but if the 450 is a gasoline tractor, then no, the valves are different lengths.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
