Re: Super MTA Starting
Posted by rustyfarmall on August 10, 2011 at 07:18:42 from (216.248.71.224):
In Reply to: Super MTA Starting posted by burowa4 on August 10, 2011 at 07:05:39:
If the hard starting is because the starter is not turning the engine, or turns the engine but is sluggish and slow, then it might be time to have the starter inspected.
If the engine turns over just fine, but the engine still doesn't want to start, then you may have an ignition problem, or a vacuum leak, or it might be time to adjust the valve clearance.
