Re: Super MTA Starting
Posted by janicholson on August 10, 2011 at 11:42:24 from (199.17.6.10):
In Reply to: Super MTA Starting posted by burowa4 on August 10, 2011 at 07:05:39:
Insufficient Bat cable wire size is a primary cause of that symptom. 00gauge wire, as short as possible, will make a great cranker out of it.
To see if it is a factor, put a set of good jumper cables in parallel with your battery cables (duplicating them, and thus making them "thicker". If it starts fine, or better, use heavier cables. Jim
