Re: farmall 560 trans problem
Posted by Janicholson on August 10, 2011 at 14:14:35 from (199.17.6.66):
In Reply to: farmall 560 trans problem posted by Skiffer on August 10, 2011 at 11:44:04:
Pretty easy fix
Remove the three bolts holding the shifter in place. Get the tractor so that the drive trail is not in a bind. (push the clutch, pull back the TA, and position so it can be rolled a little.
With a big screw driver, realign all the shift rails in the trans (good light is valuable) re install the shifter to engage the neutral slot.
Yhat is pretty much it. Welding a little metal on the shift lever tip. and making sure the pivot pin in the housing you yook off is tightm will keep it from doing it again. Jim
