Re: 240 Farmall
Posted by Janicholson on August 10, 2011 at 18:59:32 from (96.24.99.126):
In Reply to: 240 Farmall posted by luke101 on August 10, 2011 at 15:50:23:
They are seperate. The only location of commonality is between the pump seal, and the gear on the front of the pump, in the timing cover. If the seal leaks, it will fill the enging with Hydraulic oil. Jim
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
