Flat rate for R & R of the top shaft gears is a 17.8 hours. BUT that does not include any bearing replacement which requires adjustment with shims. Main shaft and/or bearing replacement bumps that up to 21.8 hours. If you replace any of the bearings on the axles or final drives that also increases the time because of needing to adjust the bearings. Washing and any extra items on the tractor also add to the time. The 30 hour figure may be realistic for someone somewhat familiar with the tractor. If they have never done the job before doubling the flat rate time may be closer to the actual time it is going to take.
In your original post on this thread you called it the reverse drive gear. I think the replies you got all addressed the reverse driven gear on the top shaft. If it is indeed the reverse drive gear on the reverse idler shaft the time would be much less. That only requires a split between the clutch housing and rear frame.
A reverse gear with a few teeth knocked out by the park lock may be run a long time without problems as long as it isn't missing two consecutive teeth. Just be careful backing up not to put too much load on the tractor.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
