Re: Bad 856 hydraulics
Posted by Owen Aaland on August 10, 2011 at 20:40:24 from (216.47.33.65):
In Reply to: Bad 856 hydraulics posted by cooop on August 10, 2011 at 19:51:52:
The hitch pump is located just in front of the left rear axle, opposite the hydraulic filter. It is mounted to the inside of that cover and comes out with the cover to remove it.
If the hitch works OK with a load on it the pump is probably still good. If not it is either the pump or a leak. Make sure the hitch position control lever is not all the way forward in the offset in the slot. That position will slow down the hydraulics.
