Posted by teddy52food on August 11, 2011 at 07:06:15 from (68.169.216.43):
In Reply to: Magneto posted by scatter on August 11, 2011 at 06:24:48:
Best is to get it to snap at TDC then leave it. If you turn it while running, it will sound and run better when it is advanced. Then if and when someone tries to hand crank it, it will kick back. Also may kick back against the starter and break the nose cone. Put it in and leave the switch off. Turn the flywheel slowly with a bar and watch the mark & listen for the snap. It should be at the mark, never before.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
