Re: Magneto
Posted by scatter on August 11, 2011 at 08:17:32 from (67.142.168.23):
In Reply to: Re: Magneto posted by Tom Fleming on August 11, 2011 at 08:06:55:
The engine has not been disassembled any further than the mag. So there should be no problems with the governor or cam gears should there? The engine has been cranked over occasionally with the hand crank just to keep it loose.
