Re: M Farmall Carb And Air Cleaner
Posted by Andrew Z on August 11, 2011 at 10:16:51 from (64.252.3.99):
In Reply to: Re: M Farmall Carb And Air Cleaner posted by sflem849 on August 11, 2011 at 07:47:35:
That does, cant be a steam pressure washer, the one my father had at work, would strip anything down to bare metal in a few seconds if you were not to careful, the old 5hp honda sure dont do that... haha
Andrew
