Re: farmall 560 trans problem
Posted by mkirsch on August 11, 2011 at 13:05:00 from (64.80.110.74):
In Reply to: farmall 560 trans problem posted by Skiffer on August 10, 2011 at 11:44:04:
Does the tractor stall out when you put it in any other gear?
If so, Janicholson's procedure will fix the immediate problem. It's stuck in 1st gear, and when you "put it in reverse" you are actually not putting it into any gear. The shifter is hitting dead air.
