Posted by Jim Becker on August 11, 2011 at 15:36:15 from (72.101.203.224):
In Reply to: Magneto posted by IH fan on August 11, 2011 at 06:24:48:
Quoting Removed, click Modern View to seeIf you know how to install a battery ignition unit,you can install a magneto. You just need to deal with 2 things.
1) Turn the magneto backwards to get the rotor pointing in the right direction. This avoids having the impulse coupling latch in.
2) After you install it, rotate the engine slowly with the crank. When the timing marks are in line, rotate the top of the mag out until the impulse clicks. Then rotate the engine slowly one more revolution, watch the timing mark. The impulse coupling should click exactly as the timing mark reaches alignment. If it doesn't rotate the top of the mag out for more advance or the opposite way for less and recheck.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
