Re: Farmall H Tranny noise
Posted by matt1983 on August 11, 2011 at 17:39:29 from (71.234.106.161):
In Reply to: Re: Farmall H Tranny noise posted by matt1983 on August 05, 2011 at 17:02:05:
Just wanted everyone to know that today I finally got it all back together. Turns out that I was right and someone did replace the original transmission pilot bearing. They used a sealed bearing and cut the inside of the old gear to fit a larger bearing. In the end I got a new input shaft and found an original bearing on ebay for 15 bucks (the dealer wanted 80!). Put it all together today and it sounds great, no grumble or noises. Guess some chewed up gears will make a lot of noise! Thanks for all the help and take care!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
