424 voltage question
Posted by capefair424 on August 12, 2011 at 05:52:45 from (174.253.151.94):
On my 1967 424 the volts at the hot side of the coil in on position are 12.2 volts but when the tractor is running the voltage is jumping all over the place from like 27+ to sometimes a negative voltage. Any help would be great. Thanks
