Re: 1066 non Ta
Posted by Les Repair on August 14, 2000 at 17:49:07 from (206.28.174.188):
In Reply to: 1066 non Ta posted by Butch-Ky on August 12, 2000 at 13:37:23:
The salvage yard is going to sell you a lot more pieces than a shaft. If you are familiar with the TA unit, you can make it non TA fairly easy. Get a couple high side fiber clutch discs from you friendly salvage yard and add these to the clutch pack. When you bolt all this up tight, you will have high side TA forever, No parts, just a lot of labor. It works. Done it several times.
Post A Followup
: Re: Re: 1066 non Ta
