Another way is to get a cheap compression guage. You can watch the compression build when it's on the compression stroke. If you go slow, you can even get a pretty good estimate on TDC by watching for the moment that the compression reverses. Go back and forth a bit and you can zero right in on it.
Get a guage with a long hose to the spark plug hole and you should be able to position the guage where you can read it while hand cranking.
By the way, if you can spin your valve stems I'm thinking you either need to adjust your valve lash because they're not seating properly - or you have very very weak springs. But that's a different issue.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
