Re: Finding TDC of compression stroke when no help available
Posted by old on August 12, 2011 at 09:16:15 from (209.86.226.61):
In Reply to: Re: Finding TDC of compression stroke when no help available posted by Duanes on August 12, 2011 at 08:39:41:
Can not spin the valves but can the push rods. You should also be able to rock the rocker arms so as o see if both more freely just enough to be able to feel the gap that should be there. Yes a straw like a soda straw will work be I would slip it in feel for the piston then pull it out and turn it a bit more and recheck not leave it in
